R31 Diff
R31 Diff
Just wondering if R31 diffs will fit in GC galants and are they straight bolt in and if not how much modding.would be involved if.they do.fit ?
Re: R31 Diff
They are okay width wise, depending on your wheels as they are wider than a Galant diff by 60mm I think.
You will need to grind off all the location tabs and weld on leaf spring mounts.
Re: R31 Diff
Thought the R31 diff was leaf springs and would already have the mounts
Re: R31 Diff
r31s are coil spring. The other option is a hilux diff, most are leaf spring but still different to galant mounts
