not starting
not starting
hey guys. i just pulled the guts out of the galant and re-fit the points (i dont have the correct coil to run the ignition yet) tried to start her and all it done was click (the starter). th ethermmo was cranking, also i checked the volts. and there was 12 volts. is there any reason this would be doing it? its not seized either. i can turn it over by hand (just. hi compression).
the battery has 420cca. the one i usually use is 540cca and it has trouble starting if the battery is a little under weather.
any ideas?
any ideas?
Re: not starting
is your battery located in the boot?
Re: not starting
nah not yet. im hoping its the battery. it was going when i pulled it apart to do the ignition. put it back together to run it. wouldnt start so i just put the points back. now it clicks. but its a different battery like i mentioned
Re: not starting
Is the cable from the battery to the starter corroded? I had an LB lancer that did this, went to give the cable a wiggle to see if it was tight and the whole lot pulled free from the crimped on eyelet that bolts to the starter, if its not that then pull the starter out and test it on the bench with some jump starters, negative to the body and positive to the post that the battery cable doesn't connect to, should have a braided cable going from it to the motor, that'll bypass the solenoid and if the motor is good it should spin. Be safe and wear PPE
Re: not starting
thanks siggylover i wil try the starter. the cable is fairly new and is not corroded. i did check and i also tightened it to the starter as it was loose. but still no difference. cheers
Re: not starting
tried to bench run the starter. nothing. and i didnt bench start it exactly. i just pulled it out. hooked it up how it should and turned the key. didnt do shit. no click. just lost all power until i let the key back to "on".
wtf?
wtf?
Re: not starting
So you left it hooked up to the car but removed it from the bell housing and turned the key? Its earthed through the bell housing so that might explain why nothing happened..
Or you mean you left it bolted to the car and used jumper leads? Negative to the body and positive to the non-switched side of the solenoid and nothing happened sounds like the motor is dead
Re: not starting
There could be another (and more simpler) solution. The ignition switch assembly. If the switches' inner contacts are buggered, it won't start due to the broken circuit. Just a thought.
Re: not starting
If he can hear the solenoid clicking the ignition switch should be right.. you really need to bypass the solenoid by applying 12v+ to the terminal on the solenoid that goes straight to the motor section of the starter.. that will tell you if the problem is the starter or notgeezer101 wrote:There could be another (and more simpler) solution. The ignition switch assembly. If the switches' inner contacts are buggered, it won't start due to the broken circuit. Just a thought.
Re: not starting
Yea I did that at the start siggylover. So I thought I was doing it wrong so I hooked it up and tried like that. Still nothing.
Re: not starting
if you did as i said then its 99% certain your motor(starter motor) is stuffed... unbolt the solenoid and keep it for a spare and ive found ebay is the cheapest place for starter motors... magna one wont work in a siggy and vice versa just in case you find a cheap magna one
Re: not starting
though if you live in a u-pull-it state that might be cheaper than fleabay
Re: not starting
astron/saturn starters are the same, last one i bought off ebay was $40
Re: not starting
http://www.ebay.com.au/itm/MITSUBISHI-L ... 3f1533d62c
$55 free shipping, though ask on here too, someone has to have one
Re: not starting
Thanks siggylover! I didn't know astron/Saturn starters are the same.
