Mods to L200's and D50's
This section is for Chrysler/Dodge D50, Mitsubishi L200/Triton, Plymouth Arrow Truck
Postby Hendrikus95 » Sat May 03, 2014 3:03 pm
Im just seeing what kind of work you guys have done to your utes, engines, brakes, steering ect.
Hendrikus95
Country: Australia (au)
Re: Mods to L200's and D50's
Postby Hendrikus95 » Sat May 03, 2014 3:57 pm
ill get it started this is my ute, 254kw at the wheels Image Image
Hendrikus95
Postby geezer101 » Sat May 03, 2014 4:47 pm
Nice EFI turbo Astron set up. Must be hard keeping power to the ground! I'd be keen to know if the front wishbones and hub assemblies are compatible from later Tritons, it would be nice to have vented discs up front (maybe a quicker steering box too)
Postby 75glnt » Sun May 04, 2014 8:44 am
Nice! :D
You can get an l300 van, and swap over the hubs on your ute :) gives you vented discs, and a 5 stud conversion! 5x114.3
75glnt
Postby geezer101 » Sun May 04, 2014 3:31 pm
75glnt wrote:Nice! :D
Then it would force my hand to change the rear to a 5 stud configuration. At the end of the day this will still be my work mule - the added expense of a diff swap isn't justified. I'll have to do a field trip to UPI and take a tape measure to see how a Triton 2WD front end compares to the L200 set up (and while I'm there get a drivers' side radius rod as mine is bent like a banana...)
Postby Hendrikus95 » Mon May 05, 2014 12:43 pm
anyone running nice 6 stud wheels?
Hendrikus95
Postby 75glnt » Tue May 06, 2014 7:31 am
I've got a set of 5 spoke alloys...
15x7 -14
Would sell em if you're keen? :)
75glnt
Postby Scorpma82 » Tue May 06, 2014 8:49 am
I'm guessing it would be relatively easy to convert the diff to a five stud pattern (Ford would be easier as they are the same PCD).....then the ratio can be changed or left accordingly to ur needs (generally they are either 3:23 or more than likely 3:45 ratio)
Postby turbol200 » Wed May 07, 2014 6:06 pm
I have a l200 with flat tray, with a 4g63 from a starion in it with mpi big front mount and all the other bits to go with nice little ute
spoto a 57 chev
...a 57 2 door
turbol200
Postby bmx537 » Wed Jul 02, 2014 11:07 am
Hendrikus95 wrote:anyone running nice 6 stud wheels?
Get onto yahoo Japan auctions through a company called import monster.
I've found heaps of awesome Japanese sport wheels in 6 stud. Just haven't had the cash to buy any yet!
bmx537
Postby woodrat » Thu Jul 31, 2014 8:01 am
woodrat
Postby geezer101 » Thu Jul 31, 2014 6:18 pm
Those of us who are inclined in all things Mitsubishi and are into their L200/Triton/D-50/MightyMax/Ram, I'd recommend checking out this US based site http://www.mightyram50.net/vbulletin/forum.php There are a few members on S-G that are also members on MightyRam50 (myself included) :thumpsup:
Postby NZL200RS » Sun Sep 14, 2014 6:06 pm
NZL200RS
Country: New Zealand (nz)
Postby colt89 » Wed Oct 15, 2014 12:33 pm
Hey guys, I've got an 85 L200 4X4, would it make sense for me to go down the turbo route, or would I be better off upgrading the carby or just going EFI considering I take it off road?
At the moment it's got a G63B from an L300 I guess and it struggles at 80kmph and the carby seems pretty routed :( ....
colt89
Postby geezer101 » Thu Oct 16, 2014 5:26 pm
Check the secondary vac actuator can on the back of the carby. If it doesn't hold vacuum then it's an easy fix - just swap it for a good one.
Postby Scorpma82 » Thu Oct 16, 2014 9:23 pm
Would seriously love to convert an L200 with my Scorpion front end I have
Postby amehel0 » Mon May 11, 2015 11:39 pm
Hendrikus95 wrote:ill get it started this is my ute, 254kw at the wheels Image Image
any work done to the engine internals to make that sort of power? building my astron l200 done the efi swap with haltech looking to see how much power i can realistically aim for
amehel0
Return to Ute's Utopia
Who is online
